1994 Saturn SL1 fuel pump voltage drops
1994 SATURN SL1
127,000 MILES • 4 CYL • FWD • AUTOMATIC
DM08262000
1994 saturn sl1 4cyl car won't crank, turns over good,firing good.Mechanic said fuel pump bad,changed it and still won't crank.Mechanic had surgery and I've got it back. I found the voltage to the fuel pump goes to 12v at start for about 10 or 15 seconds then drops to about 2v. I swapped the pump relay with another but did the same thing.
Any suggestions would be appreciated.
Jul 10, 2010 at 10:40 PM
INTERNETMECHANIC
  • 700 POSTS
Best to check voltage, engine cranking. Check the voltage at the fuel pump fuse, no need to pull fuse, there should be a bare spot over each fuse leg, check there. If the voltage does the same thing, there, check the ip/bat fuse.
https://images.2carpros.com/forum/automotive_pictures/512072_saturn_fuel_pump_circuit_1.jpg
Jul 11, 2010 at 1:25 AM
