1996 Saturn SL1 NO fuel pressure
1996 SATURN SL1
120,000 MILES • 4 CYL • FWD • MANUAL
ZHALES
The car was running good when parked several months ago. Now there is NO fuel fuel pressure to the fuel rail. What may be the cause for this? Is there a reset for the fuel pump?
Oct 31, 2010 at 12:57 PM
SATURNTECH9
  • 30,869 POSTS
Try this look at the gas tank you will see a square part that sit's a little lower then the rest of the tank.Get a hammer turn it side way's and while cranking it smack it with the hammer see if the car start's.Also do you have a multimeter?
Oct 31, 2010 at 1:02 PM
ZHALES
I do not have a multimeter. Is there a fuel pump reset switch that may have tripped that I can reset?
Nov 1, 2010 at 12:45 AM
SATURNTECH9
  • 30,869 POSTS
There is no fuel pump reset did you try what i asked you too with the hammer?Also how do you know there is no fuel pressure?Unless it start's from you cranking it and smacking it with a hammer side way's then your going to have to invest in some tool's to test it to figure it out like a multimeter to start with.
Nov 1, 2010 at 4:30 AM
