1993 Saturn Sedan Won't start
RICH99
  • 1993 SATURN SEDAN
Engine Performance problem
1993 Saturn Sedan 4 cyl Front Wheel Drive Automatic 130K miles
When trying to start car, sounds like engine is not turning over fast enough to start. Replaced battery that was only generating 10 volts. Still sounds like engine does not turn over fast enough to start.
Wednesday, December 30th, 2009 AT 6:45 PM
Load test the battery and report back ASAP.
Wednesday, December 30th, 2009 AT 7:06 PM
RICH99
Was able to get car started by pumping gas pedal repeatedly. Now car won't idle. Below about 1200 rpm the engine wants to die. Any suggestions what to look at next?
Thursday, December 31st, 2009 AT 8:45 PM
Is this an SL or SW model?
Friday, January 1st, 2010 AT 1:55 AM
RICH99
SL
Friday, January 1st, 2010 AT 11:24 PM
Check and test the idle air control valve motor, throttle position sensor and manifold absolute pressure sensor.
Saturday, January 2nd, 2010 AT 5:04 AM
