I have a 2001 SC2 3 door coupe. I was driving the other day on the freeway and had the cruise set at 72. We took a hill and the car coasted to 76. I wanted to take the cruise off and slow down so I tapped the break but it would not disengage. I then pushed the "off button" on the cruise control but it still would not turn off. I began to brake and brought the speed down but realized the accelorator was stuck down. I was able to exit and put the car in neutral at about 20 mph and then turn it off. When I turned it on, the RPMS went WAY high. I exited the car and then I heard a Pop/Thwang....and then I turned the car on and it drove normal for the remainder of the trip. Pretty scary...what is the cause, and what is the fix and how easy?
Feb 14, 2010 at 9:48 AM
