1997 Saturn SC2 water leak
230,000 MILES • 4 CYL • FWD • MANUAL
HANKTHECRANK
where is the drain that needs to be cleaned so I don't get water in the floor boards when it rains.
Jul 3, 2010 at 8:22 AM
SATURNTECH9
  • 30,869 POSTS
Do you have a sunroof?Is the water coming from the headliner?
Jul 3, 2010 at 9:09 AM
HANKTHECRANK
The water is entering through the fresh air vents below the front windshield and filling up the airconditioning ducts. The drain for the ducts under the dash is clogged. I was hoping to find out where this drain is so I can unclog it. Thanks.
Jul 3, 2010 at 11:57 AM
SATURNTECH9
  • 30,869 POSTS
Oh the a/c drain it's on the firewall engine compartment toward's the middle about half way down.Use a metal coat hanger and watch out because there is going to be alot of water comming out.
Jul 3, 2010 at 12:34 PM
HANKTHECRANK
Great answer. Thanks a lot. Went right to the drain from underneath car and reamed it out with coat hanger. Now let's see what happens when it rains.
Jul 4, 2010 at 2:59 AM
