Window?
SATURN
JORGENSENMILES
I have a 2002 L100 saturn with 80000 miles. My window is stuck in the down position. How do you know if the problem is in the switch, the motor, or regulator? And how do you take the door panel apart?
Oct 18, 2007 at 9:45 AM
BMRFIXIT
  • 19,053 POSTS
[quote:28c2505f0b="jorgensenmiles"]I have a 2002 L100 saturn with 80000 miles. My window is stuck in the down position. How do you know if the problem is in the switch, the motor, or regulator? And how do you take the door panel apart?[/quote:28c2505f0b]
When pushing the switch do you hear any movement inside the door?
Try up and down
If you do that’s mean you may need the regulator
If nothing it may be switch or wiring or motor
How to take the door panel off you have to look around the edges for screws and in the middle
Take them out remember the inside door handle too
Once panel out reconnect the window switch
You need an electric volt meter or you can use a test light
Work the switch while testing the wires at the motor for B+ and B-
And work it that way
Good luck
Oct 18, 2007 at 1:36 PM
