2002 Saturn L100 Blown Trunk Light Fuse
SATURN
DY3DM5
My son was wiring "neons" in his 2002 L100 sedan trunk and shorted the trunk light.
We can't figure out where the fuse is.
Does anything have an idea. This also killed the dome light.
Thanks for your help.
Jan 10, 2007 at 9:53 AM
SERVICE WRITER
  • 9,123 POSTS
Under body neons? Be sure to have the mechanic use the right lift or they'll get crushed :evil:
Check the underhood fuse box. Look on the left lower are there are 3 fuses. First check the bcm2 fuse, then the park lamp fuse. Should be the first one.
Jan 10, 2007 at 1:39 PM
Suggested Repair
Check the underhood fuse box, left lower area, where there are three fuses. Check the BCM2 fuse first, then the park lamp fuse; the BCM2 fuse is the likely one.
Conversation Summary
A 2002 Saturn L100 owner said neon wiring in the trunk shorted the trunk light and also killed the dome light, and they could not find the fuse. The expert advised checking the underhood fuse box, starting with the BCM2 fuse and then the park lamp fuse.
