Saturn Brake Lights Out, Fuse Blows
SATURN
ONEDURFUL
My breaklights are not working and I have replaced the blubs. I also replaced the fuse but it keeps blowing what could be the problem?
May 4, 2006 at 6:39 AM
LOSONE
  • 1,616 POSTS
It could be the stop light switch although the circuit goes through the turn signal switch.
May 4, 2006 at 8:07 AM
PEPPERMRJ
  • 1,158 POSTS
B R A K E!
For the love of pete.
You have a bad short somewhere. Have you done any mods (new sound system, etc)? If so check to see if you hit any wires in the process. If not try starting at the brake light switch on the pedal.
Sorry for the rant.
Good hunting and let us know. :)
May 4, 2006 at 8:09 AM
ONEDURFUL
Thanks for the help and suggestions. Don't worry about the rant. I would have done the same thing. :D I seeking assistance while at work and my break was on my mind.
Thanks Again
May 4, 2006 at 10:16 AM
Suggested Repair
Look for a short in the brake-light circuit. Start at the brake-light switch on the pedal, and also check the turn-signal switch since the circuit passes through it. If a stereo or other accessory was recently installed, inspect nearby wiring for damage.
Conversation Summary
The owner of a Saturn reported that the brake lights did not work after the bulbs and fuse were replaced, and the fuse kept blowing. Experts said a short was likely and suggested checking the brake-light switch at the pedal, the turn-signal switch, and any wiring disturbed by recent modifications. The owner thanked them, but no repair was confirmed.
