2001 Saturn L-Series Brake Lights Out
SATURN
TONIR2004
I have a 2001 saturn L series auto with 2.2 engine and 89,000 miles. One day both brake lights and the third brake light just quit working. In talking to some different people, they said it could be a brake switch. Is this possible? If so, where is it located so I can check it out. Note: all other lights work fine. Thanks for your help.
Sep 12, 2007 at 2:51 PM
  • 75,988 POSTS
[quote:7003e2c8ed="tonir2004"]I have a 2001 saturn L series auto with 2.2 engine and 89,000 miles. One day both brake lights and the third brake light just quit working. In talking to some different people, they said it could be a brake switch. Is this possible? If so, where is it located so I can check it out. Note: all other lights work fine. Thanks for your help.
[/quote:7003e2c8ed]
The brake switch is on the brake pedal bracket if its checks out -look for a brake light relay if it has one-could be an open brake circuit to the bulb
Sep 12, 2007 at 3:30 PM
Suggested Repair
Check the brake light switch on the brake pedal bracket. If it tests good, look for a brake light relay if equipped, and check for an open brake light circuit to the bulbs.
Conversation Summary
The owner of a 2001 Saturn L-Series reports that both rear brake lights and the third brake light stopped working while all other lights still work, and asks whether the brake switch could be the cause and where it is located. The expert says the switch is on the brake pedal bracket; if it checks out, look for a brake light relay if the vehicle has one, or an open circuit to the bulbs.
