Saturn High Beams Don't Work
SATURN
BRAT777
One night while going to work I tuned on my low beam head lights and they woked OK. Then I went to click on my high beams and they woked for a second or two then they turned off. And thats the way they are today. What is the problem with my hig beam head lights?
May 19, 2006 at 9:24 AM
PEPPERMRJ
  • 1,158 POSTS
It is possible they burnt out simaltaneously. Not likely tho. Either a bad wire or a bad multi function switch is a more likely culprit.
Good luck and let us know. :)
May 19, 2006 at 1:43 PM
Suggested Repair
Check the multifunction switch and high-beam wiring; both bulbs failing at once is unlikely.
Conversation Summary
The owner says the Saturn low beams work, but the high beams come on for a second or two and then shut off. The expert says simultaneous bulb failure is unlikely and a bad wire or multifunction switch is more probable.
