1992 Saturn Steering Column Firewall Fix
SATURN
THE.ROLLING.PIN
I have a 1992 Saturn Coupe. 2dr with 135000 miles...4 cyl EFI/SOHC 1.9l engine. I bought a steering column at the junkyard. My current column has broken plastic assembly for wiper switch. I have the dash out and the column unbolted under the dash and above the pedals. The wires are unplugged. It is still attachedn where it goes through the firewall.
How do I un-attach the column at the firewall?
Also, is it possible to switch ignition switch/cylinders or do I have to get a locksmith to make a key for the new column?
Thanx a million for any help !! the.rolling.pin@gmail.com :shock:
Mar 19, 2007 at 1:01 PM
PEPPERMRJ
  • 1,158 POSTS
Boy its been a while. The steering column main shaft should have a bolt at the very bottom that clamps it onto the shaft coming thru the firewall.
The lock cylinder is easily replaced.
Good luck and let us know. :)
Mar 20, 2007 at 10:26 AM
Suggested Repair
Remove the clamp bolt at the bottom of the steering column main shaft where it attaches to the shaft coming through the firewall. The ignition lock cylinder can be replaced separately, so a locksmith is not required to make a key for the replacement column.
Conversation Summary
The owner of a 1992 Saturn coupe has the dash removed and the steering column unbolted and unplugged, but it remains attached where it passes through the firewall. They also ask whether the ignition switch and lock cylinder can be swapped. The expert says a bolt at the bottom of the main shaft clamps it to the shaft through the firewall and that the lock cylinder is easily replaced.
