1996 Saturn SL2 Speedometer Inaccurate
SATURN
AVENGERXJ
  • 10 POSTS
1996 Saturn SL2. My speedometer is reading consistently inaccurately. It reads about 10-15 mph less than my actual speed, and at a stop it drops below 0 (it would be around -10 if there were negative numbers). Is there a way to recalibrate the speedometer or is it faulty and I should replace the gauge cluster?
Feb 24, 2007 at 8:45 AM
PEPPERMRJ
  • 1,158 POSTS
The gauges located in the instrument cluster (speedometer, tachometer, fuel gauge, voltmeter and coolant temperature gauge) are not serviceable. The entire cluster must be replaced as an assembly.
If there is no trouble code set I would suspect the guage. If there is a code you will need to test the vehicle speed sensor.
Good luck and let us know.
Feb 25, 2007 at 2:05 PM
AVENGERXJ
  • 10 POSTS
Replaced the entire cluster and everything works great.
Mar 11, 2007 at 12:23 PM
PEPPERMRJ
  • 1,158 POSTS
Thanxs for the update. I am glad for the positive outcome.
Mar 11, 2007 at 1:32 PM
Suggested Repair
The instrument cluster gauges are not serviceable, so replace the cluster as an assembly. If a trouble code is set, test the vehicle speed sensor before replacing the cluster.
Conversation Summary
A 1996 Saturn SL2 speedometer read about 10-15 mph low and dropped below zero when stopped. The expert said the cluster gauges are not serviceable and the whole cluster must be replaced, and that a trouble code would call for testing the vehicle speed sensor. The owner replaced the cluster and reported that everything worked correctly.
