1996 Saturn SL2 Headrest Removal
TOTALCLUB
I have a 1996 Saturn SL2 with 112,000 miles.
My question is how do you remove my headrest? I recently purchased seat covers and the headrest doesn't just pull off or have a release button. Do you have any info on how to remove my headrest?
Apr 7, 2006 at 6:47 AM
PEPPERMRJ
  • 1,158 POSTS
I'm not sure if the 96 is like the old 93. I'd have to go out and look. Not tonight.
The older models you should have a small notched hole in the plastic anchor that the head rest posts slide in. Stick a small screw driver into that notch about inch or two. Then the screw driver will make contact with the stopping mechanism that keeps you from pulling out the headrest when you fully raise it. Push in on the screwdriver to disengage the lock while you pull up on the headrest.
If you need to remove the plastic anchor you will have to get under the upholstry to remove the clips that hold it in.
Good luck and let us know. :)
Apr 7, 2006 at 2:02 PM
TOTALCLUB
Thank you, It worked on the passenger side, It looks like I'm going to have to get someone to help on the driver side, it just doesn't want to come off. I actually tried this yesterday on the driver side but not on the passenger side. I know it seem like a minor problem but thanks for your help.
:) totalclub
Apr 8, 2006 at 7:41 AM
PEPPERMRJ
  • 1,158 POSTS
Try a little penetrating oil or WD40. Wait a bit and give it a good yank.
Apr 8, 2006 at 11:23 AM
TOTALCLUB
I got it with a little help from a friend.
Thanks for all your input.
Totalclub
:D
Apr 8, 2006 at 12:25 PM
Suggested Repair
Insert a small screwdriver into the notched hole in the plastic headrest post anchor to disengage the stop, then pull the headrest upward. If it is stuck, apply penetrating oil, wait, and pull firmly. Removing the plastic anchor requires accessing the retaining clips under the upholstery.
Conversation Summary
The owner of a 1996 Saturn SL2 asked how to remove the headrests for seat covers because they would not pull off and had no release button. The expert described using a screwdriver in the notched plastic anchor to release the lock while pulling up, and suggested penetrating oil if stuck. The owner confirmed both headrests came off with help.
