1994 Saturn SL2 Speedometer Out
SATURN
MUSP
I have a '94 SL-2 that I cannot seem to figure out where the speed sensor is located.
I had the air filter box and battery pulled out for a week while I was waiting for a part to come in and some squirrels must have gotten in there and chewed on at least one wire. I have repaired the only wire I can find that has been chewed on, but now the speedometer doesn't work and I can only assume it is a bad wire. I cannot find any more wires that have been chewed on, but I really don't know specifically where to look.
Even verifying that the speed sensor is electric rather then mechanical would be a help.
Mar 14, 2007 at 2:46 PM
PEPPERMRJ
  • 1,158 POSTS
It's electric.
https://images.2carpros.com/forum/automotive_pictures/4270_saturn_speed_sensor_1.jpg
Good hunting and let us know. :) Ps. Give the squirrels a bird feeder with seed to play with.
Mar 15, 2007 at 12:26 PM
MUSP
Thanks for the response. Two questions though:
1. My car is an automatic, would it be roughly the same?
2. Is that the rear of the transmission?
Mar 15, 2007 at 2:20 PM
PEPPERMRJ
  • 1,158 POSTS
[quote:d92aa81d08="musp"]Thanks for the response. Two questions though:
2. Is that the rear of the transmission?[/quote:d92aa81d08]
I do believe so to both questions. I would have to go outside to check in the snow so I'll leave that to you. :)
Mar 16, 2007 at 2:36 AM
MUSP
Thanks for the help. I was able to find the sensor (had to come in from the bottom to see it). There was about 6 inches of wire just gone between the sensor connection and the wire bundle that it fed to. So I just soldered some wire in there and the speedometer now works.
Thanks again for the help.
Mar 16, 2007 at 11:04 AM
PEPPERMRJ
  • 1,158 POSTS
Congrats! Love a happy ending, :)
Thanks for the update.
Mar 16, 2007 at 11:26 AM
Suggested Repair
The speed sensor is electric and is located at the rear of the transmission; access is easier from underneath. Inspect the wiring between the sensor connector and the harness for missing or chewed sections, then splice and solder in replacement wire.
Conversation Summary
The owner of a 1994 Saturn SL2 automatic could not locate the speed sensor after squirrels chewed wiring near the battery and air filter box, and the speedometer stopped working. An expert confirmed the sensor is electric, likely at the rear of the transmission on an automatic as well. The owner found the sensor from underneath and repaired about six inches of missing wire between the sensor connector and the harness by soldering in new wire, which restored the speedometer.
