1993 Saturn SL2 Vacuum Noise
SATURN
MKFRANCIS
I drive a 93 sl2 w/105k miles It makes what I call a loose vacuum hose type noise especially when cold. A neighbor told me this was a noise produced to inform me of a brake problem ...is this for real? It doesn't just make this noise when the wheel turns it goes more along with engine rotoaton than that. Does this sound familiar to anyone?
Jan 11, 2007 at 11:59 AM
PEPPERMRJ
  • 1,158 POSTS
Disc brake pads will make a squeeking noise when they get low.
Check your vacuum lines. PCV, EGR, etc. Also check arounfd the intake manifold for a leaking gasket,.
Good luck and let us know. :)
Feb 7, 2007 at 10:36 AM
Suggested Repair
Check vacuum lines, including the PCV and EGR circuits, and inspect the intake manifold gasket for leaks. Low disc brake pads can squeak, but a noise that follows engine speed is more consistent with a vacuum leak than a brake warning.
Conversation Summary
The owner of a 1993 Saturn SL2 with 105,000 miles hears a loose vacuum-hose type noise, especially when cold, that follows engine rotation rather than wheel movement. A neighbor claimed it was a brake-problem warning. The expert notes that low disc pads can squeak and recommends checking vacuum lines, the PCV and EGR systems, and the intake manifold gasket.
