1999 Saturn SC1 Squealing Belt
Suggested Repair
Inspect the serpentine belt and pulleys with the engine running and someone turning the steering wheel. A belt slipping on a pulley that is not turning adequately can explain the squeal, hard steering from a non-turning power steering pump, and the battery light from a non-turning alternator.
Conversation Summary
The owner of a 1999 Saturn SC1 with 135,000 miles reported a loud squeal that grew louder under throttle, a flickering or flashing battery light, and briefly hard steering. The belt was replaced about three years earlier and the battery is about four years old. The expert said the belt is likely slipping on a pulley that is not turning properly, affecting the power steering pump and alternator, and advised watching the belt and pulleys under the hood while someone turns the steering wheel.
