Saturn Intermittant wipers
SATURN
VERNK
Saturn SL2 1998 107,000 miles, Once turned on my wipers will not turn off unless I turn off the ignition while they are in the park position, Sometimes it takes a couple of tries. Also the wipers run @ slow, fast, intermittant or whatever they decide when I do have to use them. :twisted: If you think the problem is the Wiper Control Module, Where is it located? Thanks :!:
May 2, 2006 at 3:15 AM
LOSONE
  • 1,616 POSTS
The wiper control module is built into the wiper motor. They used to be available as a unit but now you have to buy the entire motor assembly. Good luck
May 2, 2006 at 4:57 AM
