1998 Saturn SL2 Windows Click No Move
1998 SATURN
ARCHANGEL82
I have a 1998 Saturn SL2, 106388 miles Both of my drivers side windows have stopped working in the past year. Both started having some problems rolling up before they quick working completely. Now when I push the window button you hear a click at the motor inside the window but no other noise. Is this a sign that my motor has gone out or is there some other problem?
Mar 17, 2007 at 11:40 AM
PEPPERMRJ
  • 1,158 POSTS
I would start by checking the switch. Make sure the power in and out is a full 12 volts or more.The drivers window is used the most so it will normaly be first to wear.
Good luck and let us know. :)
Mar 18, 2007 at 7:44 AM
Suggested Repair
Check the window switch and confirm power in and out is a full 12 volts or more before assuming the motor has failed. The driver's window is used most and typically wears first.
Conversation Summary
The owner of a 1998 Saturn SL2 says both driver-side windows stopped working after having trouble rolling up. Pressing the switch produces a click at the motor but no movement. The expert recommends checking the switch and verifying full 12-volt power in and out, noting that the driver's window usually wears first.
