1996 Saturn SL2 Turn Signals Not Working
GMC
SATRUNSL296
Last night, I found that my right turn signal was not working. Actually, it seemed to be a loose contact. So, I opened the tail light assembly to check the bulb. Now, neither of the turn signals are working. :(
The bulb looked good though loose. Any inputs would be appreciated.
Thanks
SATURN SL2 '96
Feb 2, 2006 at 1:28 AM
CHEVY350GUY
  • 109 POSTS
check flasher. it should be under the dash. make sure there is power at it with key on and turn signal on. if yes replace flasher. if no check fuse. also grease the base of the bulds this will improve stability and contact. let me know if it does not work.
Feb 2, 2006 at 1:59 AM
SATRUNSL296
Thanks chevy350guy.
I shall give it a try and let you know.
Feb 2, 2006 at 2:14 AM
Suggested Repair
Check the turn-signal flasher under the dash. With the key on and a turn signal selected, verify power at the flasher; replace the flasher if power is present, or check the fuse if it is not. Also grease the bulb bases to improve contact and stability.
Conversation Summary
The owner of a 1996 Saturn SL2 reported that the right turn signal failed, apparently from a loose contact. After opening the tail-light assembly and finding the bulb intact but loose, both turn signals stopped working. The expert advised checking the under-dash flasher for power with the key and turn signal on, replacing it if powered or checking the fuse if not, and greasing the bulb bases. The owner said they would try those steps.
