1998 Saturn SL2 Wipers Won't Turn Off
SATURN
VERNK
Saturn SL2 1998 107,000 miles, Once turned on my wipers will not turn off unless I turn off the ignition while they are in the park position, Sometimes it takes a couple of tries. Also the wipers run @ slow, fast, intermittant or whatever they decide when I do have to use them. :twisted: If you think the problem is the Wiper Control Module, Where is it located? Thanks :!:
May 2, 2006 at 3:15 AM
LOSONE
  • 1,616 POSTS
The wiper control module is built into the wiper motor. They used to be available as a unit but now you have to buy the entire motor assembly. Good luck
May 2, 2006 at 4:57 AM
Suggested Repair
Replace the wiper motor assembly. The wiper control module is built into the motor and is no longer sold separately.
Conversation Summary
A 1998 Saturn SL2 owner reported that the wipers would not shut off unless the ignition was turned off with the wipers in park, sometimes requiring several tries, and that they ran at random speeds. The expert said the wiper control module is built into the wiper motor and must be replaced as a complete motor assembly.
