1998 Saturn SL1 Overheating and Coolant Leak
Also have you checked and or replaced the ects (coolant temp sensor). The original ones from saturn had a plastic tip that would crack. Yours would be due if it is original. Replace it with the updated brass tip design from saturn.
That would cause the high idle and poor fuel economy and also they leak. Check the pigtail while you are at it. Replce it also if it is too far corroded.
Good luck and let us know. :)
Suggested Repair
Have a shop perform a coolant pressure test to locate the orange coolant leak and any related pressure loss. If overheating occurs only at idle, check whether the electric cooling fan is working. Also inspect the coolant temperature sensor; replace an original plastic-tip sensor with the updated brass-tip design and replace the connector pigtail if it is corroded.
Conversation Summary
The owner of a 1998 Saturn SL1 with 97,500 miles reports an orange fluid leak near the front driver's side, a hot radiator smell, overheating at idle in park or neutral, a high idle in park, and a hard shutdown. The car otherwise runs well and gets about 30 mpg. Experts identify the fluid as antifreeze and recommend a coolant pressure test, checking the electric fan if the problem occurs only below about 30 mph, and replacing a possibly cracked original coolant temperature sensor and corroded pigtail.
