1996 Saturn SL1 Gasoline Leak
SATURN
ZOCVJP
I have a 1996 Saturn SL1 with 180,000 Miles. Last night upon returning from a short ride to the store I smelled gasoline after I parked the vehicle. I pulled the vehicle forward and found a small pool under the front tire on the driver's side. Upon looking, I noticed the car left a trail up the whole driveway about 100 feet.
Just was curious of the possible causes, fuel line, fuel pump?
The car is on it's last leg and I'm not sure if it's worth the repair.
Apr 22, 2007 at 11:37 PM
PEPPERMRJ
  • 1,158 POSTS
Hey Z,
Most likely a fuel line. The fuel filter on my 96 SC2 is locarted slightly rear of the drivers front tire. Might be a loose connection there also. Your Satty is just getting broke in as long as you never let the oil run out. :)
Good luck and let us know.
peppermrj
Apr 23, 2007 at 1:31 PM
Suggested Repair
Inspect the fuel line and connections at the fuel filter, located slightly behind the driver's front tire, for a leak or loose fitting.
Conversation Summary
The owner of a 1996 Saturn SL1 with 180,000 miles smelled gasoline after a short trip and found a small pool under the driver's front tire plus a trail along the driveway. The expert said a fuel line is most likely, possibly a loose connection at the fuel filter just behind that tire.
