1996 Saturn SL2 Running Hot
What happens is that your car gains heat because there is no air rushing through the radiator when you are in park. Also, the fans most likely wont kick on until more like 3/4th on the gauge.
Turning on the A/C increases idle RPM which means your car will get hot even faster.
Your car may get warm when driving around town at say 25 mph with many stoplights, once again just because the radiators won't work as well without all of the air rushing past them.
I guess I am saying it sounds as though things may be normal..... I would be concerned however if you are driving in similar conditions to what you are use to (not flooring it, same temps outside, same speeds) and the operating temps have increased.
Depending on what state you are in, your car may be close to a recommended radiator flush.
About the A/C:
If you are in your car and press the a/c button to turn it on, you should be able to hear the compressor kick on. If this is the case you may see a small ~100-200 rpm gain in idle speed which should settle back down some within a second or two.
If it doesnt your compressor may be bad, or you may just need new O-rings.
If it clicks on but blows warm air you may need an A/C recharge, or even just O-rings.
I would recommend always having the O-rings inspected before A/C compressor replacement. It saved me hundreds of dollars once. Just remember that the A/C lines are very dangerous.
Like guitardude says might just be normal. I have a 96 SC2. the temp on the gauge runs around a little bellow half normally. It will kick the cooling fan on at about the 3/4 mark. The fan will remain on till the gauge goes down to 5/8ths and then it will shut off. Let the car idle and watch that the cooling fan is coming on. It will take 10 to 15 minutes even on a warm day.
If you have to add coolant on a regular basis, start looking for a leak. Dried coolant will leave a whiteish stain. Check the coolant tank, around all the hoses, the thermostat housing, and the radiator. The rad has a tendency to crack around the top hose mount. Also look at the waterpump. Best viewed from underneath. When it leaks it throws coolant around and is hard to spot.
If your heating is not up to par the first thing that comes to mind is a low coolant level. After that a clogged heater core. Try reverse flushing it. Also the temp controll cables might be sticking or the heater door not opening all the way. Poor coolant flow (waterpump) can be a prob also.
Check that the ac compressor is engaging like the guitardude recommends. If it is engaging and you are still getting warm air again check the heater/AC controls.
Good luck and let us know. :)
peppermrj
The fix mentioned was to adjust the compressors suction set point.
If this is indeed the problem, it should be an easy fix. The AC should be easy to reach and you only need an exacto knife, screwdriver, and a sharpie.
Suggested Repair
Confirm whether the higher gauge reading is normal by letting the car idle and watching for the cooling fan to come on around the three-quarter mark. If coolant must be added regularly, inspect for leaks at the reservoir, hoses, thermostat housing, radiator top hose mount, and water pump. For weak heat, check coolant level, reverse-flush the heater core, and inspect heater controls and coolant flow. For warm A/C, verify that the compressor engages; if it does not cool, consider a recharge and have the O-rings inspected before replacing the compressor.
Conversation Summary
A 1996 Saturn SL2 with 86,000 miles began running above its usual roughly 3/8 temperature-gauge reading after short idling and sometimes while driving. A small amount of 50/50 coolant was added. The A/C sometimes blows warm air, and the heater has not seemed as hot since the radiator assembly and thermostat were replaced about two years earlier. Replies say the rise may be normal because airflow is limited at idle and the fan may not start until near 3/4. They recommend watching fan operation, checking for coolant leaks if topping off continues, and investigating low coolant, a clogged heater core, controls, or poor flow for weak heat. For the A/C, they advise confirming compressor engagement and checking for low refrigerant or faulty O-rings before compressor replacement.
