Saturn Antifreeze in Gas Tank
SATURN
CONCERNED DAD
My son ran out of gas in his Saturn lat night, a passerby told him it was safte to put radiator antifreeze in his gas tank to get him to the gas station. It worked, but I am concerned about what problems this will cause to his engine. Should the gas line and gas tank be drained?
Mar 18, 2006 at 2:03 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. :)
Are you serious? :shock: Better yet is he serious? :twisted: Let me know if he was pulling your and my leg. If he was smack him one for me too. :wink: That is a new one on me. I would be running fuel injector cleaner for the next several tankfulls. Chevron with techron works well for me.
Good luck and let us now?
Mar 18, 2006 at 3:20 PM
CONCERNED DAD
:( Yes, unfortunately I am serious. Pretty obvious that my son is not mechanically inclined. Anyways, He did use some gas line antifreeze and used the rest of the radiator antifreeze he had in his trunk as well. Antifreeze is antifreeze, so he thought. Thanks for the advice :) . Hopefully he learned a valuable lesson :wink:
Mar 18, 2006 at 10:42 PM
PEPPERMRJ
  • 1,158 POSTS
Did a little research. A few years back (1999) a new product was non flamable emergency gas (fuel addititive). Billed as save to store for up to 5 years and sold in about a half gallon container. It was supposed to let the car run for several miles to the gas station.
There was concern that it was harmfull to the fuel system of your car and should only be used once. I looked up a few manufacturers (prestone and pennzoil) that originally sold the stuff. Neither list the product anymore on their websites. It is also not listed by most autoparts houses.
I am assuming that it is not still marketed for a reason. That being that is wasn't good for continued use. I am also assuming that the antifreeze is the same type of deal. Go with the fuel injector cleaner.
Thanxs for the update and the interesting topic. Let us know if your son does have any trouble with his Saturn. :?: I learn something new everyday on this site. :)
Mar 19, 2006 at 2:41 AM
Suggested Repair
Run a fuel injector cleaner such as Chevron with Techron through the next several full tanks. The expert did not recommend draining the tank or lines; monitor the Saturn for fuel-system problems after the one-time antifreeze use.
Conversation Summary
A Saturn ran out of gas, and radiator antifreeze plus some gas-line antifreeze was added to the tank so it could reach a station. The owner asked whether the tank and fuel lines should be drained because of possible engine damage. The expert recommended fuel injector cleaner, specifically Chevron with Techron, for several tankfuls, compared the incident to discontinued emergency fuel additives not meant for repeated use, and asked to be updated if problems appeared.
