Saturn Oxygen Sensor Location
SATURN
BENSTAUBER
where are the oxygen sensors located? I have the 1.9 DOHC engine with two sensors. My local mechanic told me to do it myself with a 3/8" wrench.
help!
Apr 22, 2006 at 4:09 AM
PEPPERMRJ
  • 1,158 POSTS
They're are two. The front one is readily accessible from the front of the car. It is located in the exhaust manifold. Sort of looks like a spark plug with a thin wire attached to it.
The second is located either at the end of the catylitic convertor or the pipe right after it. A little tougher to acccess.
Both can be change but I would recommend purchasin the special socket for each of them. Some auto parts stores even rent or loan them for free.
How do you know they need to be replaced?
Apr 22, 2006 at 9:57 AM
Suggested Repair
Locate the front oxygen sensor in the exhaust manifold and the rear sensor at the end of the catalytic converter or the pipe just after it. Use a special oxygen-sensor socket, which many parts stores loan, rather than a 3/8 wrench.
Conversation Summary
The owner of a Saturn with a 1.9 DOHC engine asked where its two oxygen sensors are located after a mechanic suggested replacing them with a 3/8 wrench. The expert said the front sensor is in the exhaust manifold and accessible from the front, while the rear sensor is at the end of the catalytic converter or in the pipe just after it. A special socket was recommended, and the owner was asked why replacement was needed.
