oxygen sensor
SATURN
WOLFIE49
I have a 2001 SL1. I have a check engine code PO137, oxygen sensor 2 in bank 1 should be replaced. My question is this: is this easy to do myself and where exactly is this located so I can change it? If you have a diagram it would be very helpful. Thanks.
Oct 29, 2007 at 10:47 AM
2CARPRO JACK
  • 11,533 POSTS
No diagram necesary. That is the one after the catalytic converter, nearest the tail pipe. A 7/8 wrench is all you should need
Oct 29, 2007 at 10:51 AM
