It was not the sensor
SATURN
LOZOYA29
  • 5 POSTS
Saturn 1993 SL 1.9 4 cyl. 102000 miles manual trans.
I changed the ECTS, the check engine is gone, and everything looks normal, but the cooling fan that does not turn on.
I am going to make a quick fix putting a jumper to the relay to have it turn on with the car. But I still want to fix it the right way.
Now what should I do!!!!?????
Apr 18, 2007 at 3:08 AM
PEPPERMRJ
  • 1,158 POSTS
Hey E,
The cooling fan kicks in when my gauge hits almost 3/4s. It runs untill the gauge gets down to about 1/2. If this is not happening you need to first make sure the motor runs. If the AC works you can simply turn the ac on and the fan should come on within a minute or so. If the cooling fan does not work check to see if there is power at the fan. Jump the fan with a 12 volt line and see if comes on. Also make sure it has a good ground! I can give you further instuctions if needed.
Good luck and let us know. :)
peppermrj
Apr 23, 2007 at 2:49 PM
LOSTINMARS
  • 222 POSTS
change the cts connector as well
May 1, 2007 at 1:30 PM
