ignition lock cylinder for a 2001 saturn L100
2001 SATURN
NACHO2NACHO
How do you remove the ignition lock cylinder on a 2001 saturn L100 car? I can't get it out and the key won't turn at all.
Apr 18, 2006 at 2:54 AM
PEPPERMRJ
  • 1,158 POSTS
Most times there is a pin that is depressed when the lock cylinder is in the run position. Not sure if the steering wheel needs to be removed or just the plastic housing. I would recommend purchasing a manual for the exact procedure. Either a Haynes or Chilton should have what you need. Airbags can be explosive. :)
Have you tried turning the steering wheel both ways. Sometimes that is all it take. It can require some muscle tho.
Good luck and let us know.
Apr 18, 2006 at 4:11 PM
