1994 Saturn Grinding Between Gears
SATURN
BIGTOYZ
1994 Saturn, high mileage... everytime i shift it grinds going into every gear. But when i put it into neutral and wait a few seconds before going into another gear it goes into gear perfect? i have exhausted my ideas for this problem and am unsure on what the problem is... thank you in advance for your input!
May 12, 2006 at 4:44 AM
PEPPERMRJ
  • 1,158 POSTS
There are bushings at both ends of the shift cable that wearout. This can cause problems with going into gear. Replace the cable.
Good luck and let us know. :)
May 12, 2006 at 5:14 AM
Suggested Repair
Replace the shift cable. Worn bushings at both ends of the cable can prevent clean engagement and cause grinding when shifting into gear.
Conversation Summary
The owner of a high-mileage 1994 Saturn reports grinding when shifting into every gear, but the transmission engages smoothly if left in neutral for a few seconds first. The expert says worn bushings at both ends of the shift cable can cause this and recommends replacing the cable.
