1993 Saturn SL2 Compression Spec
SATURN
PIXIEDUST
1993 saturn sl2, 4 cylinder , 160,000 miles,what is the engine compression supposed to be?
engine idles high when first started, then it bogs down and will not accelerate, wanted to check engine compression, but don't know what it's supposed to be.
May 18, 2007 at 12:59 PM
SERVICE WRITER
  • 9,123 POSTS
It's kinda goofy the way they list it. On one hand they say no cylinder should be under 100 psi. Then they say the minimum should be 180. But the spec they list is 185-205 psi
May 18, 2007 at 1:22 PM
Suggested Repair
Check compression on all cylinders against the listed 185-205 psi specification. No cylinder should be under 100 psi, and the stated minimum is about 180 psi. Compare readings between cylinders.
Conversation Summary
The owner of a 1993 Saturn SL2 with 160,000 miles asked for the correct engine compression specification after high idle on startup followed by bogging and no acceleration. The expert noted conflicting published figures but listed the specification as 185-205 psi, with no cylinder under 100 psi and a minimum around 180 psi.
