1997 Saturn SL2 Heater Blows Cool
SATURN
DCR
I have a 1997 Saturn SL2 with 122,000 miles. i'm having heater problems. this has been ongoing for about a year. when my heater started blowing cool air, i told my mechanic about it and he just topped off the antifreeze, which didnt seem to solve the problem. then he replaced the thermostat. it seemed to blow "warmer" air for a while, but now, it's a little complicated. i will turn the heater on when the engine is warm, and it blows warm air for a while out of the top air vents, but then the air gets cooler, and the air from the floor vents is always cool. also, my airconditioner doesn't cool as well as i would like. would the heater/airconditioner problems be related? my mechanic mentioned possible water pump problems, which he will be checking for in a few days. i have no leaks, and the antifreeze jug seems to retaining its liquid. any solutions or suggestions?
Jan 13, 2007 at 10:19 AM
PEPPERMRJ
  • 1,158 POSTS
A water pump is a possibility if it is the original one.
Is the cooling (radiator) fan running constantly?
It also could be in the heater controls. The temperature adjustment cable and the mode cable should move freely.
Good luck and let us know. :)
Feb 7, 2007 at 10:48 AM
Suggested Repair
Check whether the radiator cooling fan runs constantly and confirm the heater temperature and mode cables move freely. An original water pump is also a possible cause and should be inspected.
Conversation Summary
The owner of a 1997 Saturn SL2 with 122,000 miles reports that the heater blows warm air briefly from the upper vents, then cools, while the floor vents stay cool. Coolant was topped off and the thermostat was replaced, with no visible leaks, and the air conditioning also cools poorly. The expert says an original water pump is possible, asks whether the radiator fan runs constantly, and suggests checking that the heater control cables move freely.
