1991 Saturn SL2, 151k, Low Compression Cylinder 1, Car Jerks
1991 SATURN
IGLEN31
Vehicle has 151,000+ miles on it (odometer stopped working). The vehicle idles hard. Brought it into the shop and ran computer test. Came back and showed only 50psi compression in cylinder 1, only got up to about 100psi with wet test when it should be around 150 for each cylinder. Recently while driving the car, it started jerking randomly, felt kinda like a very hard transmission slip. Now it does it fairly regularly. It also seems that it burns more oil than normal. I recently changed spark plug wires (original) and will change fuel filter. Was told it could be a valve problem or possibly timing chain set that needs to be changed. Any suggestions or similiar problems?
Apr 19, 2007 at 8:10 AM
PEPPERMRJ
  • 1,158 POSTS
Sounds kind of bad.
A failing timing chain rattles and sounds like a diesel engine. The niose will increase as the motor revs higher.
A leakdown test will narrow it down to either valves or rings. Either way it is time for major repairs.
Good luck and let us know. :)
peppermrj
Apr 24, 2007 at 3:53 AM
