1993 Saturn SL Coolant Leak
SATURN
LUCASB
93 saturn SL 4-door approx. 182,000 miles I recently replaced the cooling fan in my car and now it is leaking coolant. I am having to add more coolant almost everyday because the leak is so bad. I'm wondering what would cause the leak?
Sep 19, 2007 at 7:16 AM
MERLIN2021
  • 17,250 POSTS
It depends where it leaks from! If the overlow tank is releasing it , it's one thing, but if it's from the engine, or radiator it's another, Pressure test it to find the leak! I suspect the fan installation may have poked a hole in the radiator!
Sep 19, 2007 at 8:13 AM
LIFEBALLA00
[quote:fbb58d204b="merlin2021"]It depends where it leaks from! If the overlow tank is releasing it , it's one thing, but if it's from the engine, or radiator it's another, Pressure test it to find the leak! I suspect the fan installation may have poked a hole in the radiator![/quote:fbb58d204b]
Same thing is happening to my saturn. Where is the overlow tank located? It seems that the leak is connected to something under/ or at the bottom of the car. I don't think it would be the radiator, b/c it would be leaking in the front of the car. It may be the overlow tank or the engine. If so then what? Also my passenger side windowshield wiper isn't working. Is that an electrical problem or do i need to replace windowshield wiper motor for the passenger side if it has one? If so where is it located?
Thanks
Sep 20, 2007 at 6:33 AM
Suggested Repair
Pressure-test the cooling system to locate the leak. Inspect the radiator for damage from the recent cooling-fan installation, and also check the overflow tank, hoses, and engine area.
Conversation Summary
The owner of a 1993 Saturn SL with about 182,000 miles reports a severe coolant leak after replacing the cooling fan and must add coolant nearly every day. The expert says the cause depends on the leak location and recommends a pressure test, suspecting the fan installation may have punctured the radiator. A second Saturn owner reports a similar leak underneath the car and an inoperative passenger windshield wiper; those questions were not answered.
