1998 Saturn SL2 Coolant Leak
SATURN
DKCOPE84
hi,
i have an automatic 1998 saturn sl2 4 cylander with about 111,000 miles. recently the coolant light keeps coming on. when i first checked it the coolant was low so i refilled it. then a few weeks later it came on again. it was low. i figure there's a leak somewhere but i dont see a wet spot in my parking space. where should i look? is this something serious?
thanks in advance!
de
Apr 26, 2007 at 5:34 AM
WSCREATE
  • 59 POSTS
[quote:b714f125ab="dkcope84"]hi,
thanks in advance!
de[/quote:b714f125ab]
The worst case scenario is if you have coolant leaking internally such as with a bad head gasket or cracked block. That's the worst case. Does the car smoke out of the tail pipe? Is there any liquid coming out of the exhaust when running?
Apr 26, 2007 at 6:54 AM
PEPPERMRJ
  • 1,158 POSTS
Hey dkcope84,
Sounds just like what happened on my 96 with about the same mileage. On mine it was the waterpump. As it leaked the spinning pulley would throw the water around so it did not leave much of a puddle. It got progessively worse (the leak). I had to put the car up on jackstands and look from underneath to find the leak. No biggie. The pump goes for under $30.00. I put it on myself from the passenger wheel well. I can send detailed instructions if you like.
The other thing that comes to mind is the pressure cap on the coolant tank. It can fail but that does not happen often.
Good hunting and let us know. :)
peppermrj
Apr 26, 2007 at 10:01 AM
DKCOPE84
[quote:70db4b56d2="wscreate"]
The worst case scenario is if you have coolant leaking internally such as with a bad head gasket or cracked block. That's the worst case. Does the car smoke out of the tail pipe? Is there any liquid coming out of the exhaust when running?[/quote:70db4b56d2]
there isnt any smoke but i'll have to check for liquid coming out of the exhaust.
[quote:70db4b56d2="peppermrj"]
Sounds just like what happened on my 96 with about the same mileage. On mine it was the waterpump. As it leaked the spinning pulley would throw the water around so it did not leave much of a puddle. It got progessively worse (the leak). I had to put the car up on jackstands and look from underneath to find the leak. No biggie. The pump goes for under $30.00. I put it on myself from the passenger wheel well. I can send detailed instructions if you like.[/quote:70db4b56d2]
if i find thats where the leak is i'll be back for the instructions. :D
thanks for the responses!
Apr 27, 2007 at 6:40 AM
Suggested Repair
Inspect underneath on jack stands for a water pump leak, since a spinning pulley can throw coolant and leave little or no puddle. Also check the coolant pressure cap and look for exhaust smoke or liquid that could indicate an internal leak such as a head gasket or cracked block.
Conversation Summary
A 1998 Saturn SL2 with about 111,000 miles repeatedly loses coolant and triggers the coolant light, but no puddle is visible. One reply warns that an internal leak from a bad head gasket or cracked block is the worst case and asks about exhaust smoke or liquid. Another reports a similar leak from a water pump that sprayed coolant rather than pooling, found from underneath, and notes the pressure cap as a less common possibility. The owner reports no smoke and plans to check the exhaust and water pump.
