1999 Saturn Battery Drain
1999 SATURN
GFINNEY77
My saturn died the other day. Jumped it and it started right back up. Died again when I got home. Hooked a voltimeter up and am having issues. Battery post registers @ 3 volts. Disconnect the IP BATT (30a) fuse and it reads fine at 12 volts. What is this fuse too and how can I find the drain?
Thanks,
Gerry
Apr 10, 2007 at 2:25 PM
SERVICE WRITER
  • 9,123 POSTS
Here is the list of circuits:
https://images.2carpros.com/forum/automotive_pictures/30961_sat_1.jpg
Your going to have to isolate to find the problem. You'll need wiring diagrams most likley.
Apr 10, 2007 at 2:35 PM
PEPPERMRJ
  • 1,158 POSTS
Start pulling fuses for the individual circuits servicewriter listed and see what gives.
Good hunting and let us know. :)
peppermrj :)
Apr 10, 2007 at 7:24 PM
Suggested Repair
Isolate the parasitic drain by pulling the individual circuit fuses fed by the IP BATT 30A fuse and noting which one restores normal battery voltage. Use wiring diagrams to identify those circuits and trace the draw.
Conversation Summary
The owner of a 1999 Saturn reports that the vehicle dies and the battery reads about 3 volts, but voltage returns to about 12 volts when the IP BATT 30A fuse is disconnected. Experts advise isolating the drain by pulling fuses for the listed circuits and consulting wiring diagrams.
