2003 Saturn VUE Electrical Failure
2003 SATURN
GREAZILLA
I recently installed an after market cd player in my 2003 Saturn VUE and then uninstalled it after discovering it was damaged (I took it out of a car that had been in a pretty bad accident).
Upon reinstalling the factory cd player in the dash I discovered that now all of a sudden the interior lights, dimmer, gauges, service lights, door locks and power steering were all non-operational.
I checked all the fuses under the hood and and only one 20 amp fuse was blown as far as I could tell and I replaced it. However, the problems still continued without change.
Any suggestions on what might be the problem?
Apr 25, 2007 at 6:53 AM
PEPPERMRJ
  • 1,158 POSTS
Hey greazilla,
It has been my experience that there are normally two fuse boxes. One underhood and the other in the passenger compartment. Be sure to check all the fuses. I have found the use of a test light or an ohm meter helpfull in checking fuses. Sometimes looks can be deceiving!
Good hunting and let us know. :)
peppermrj
Apr 25, 2007 at 11:45 AM
GREAZILLA
thanks ... i found the second fuse box and everything is running great now. strange that the power steering is an electrical issue, never seen that before.
Apr 25, 2007 at 1:00 PM
PEPPERMRJ
  • 1,158 POSTS
Love happy and inexpensive endings. :D Thanxs for the update.
peppermj
Apr 26, 2007 at 1:38 AM
Suggested Repair
Check the passenger-compartment fuse box as well as the underhood fuses, using a test light or ohmmeter rather than visual inspection alone. A blown interior fuse restored the lights, gauges, locks, and power steering.
Conversation Summary
After reinstalling the factory CD player in a 2003 Saturn VUE, the interior lights, dimmer, gauges, service lights, door locks, and power steering stopped working. Replacing one blown 20-amp underhood fuse did not help. The expert advised checking the second fuse box in the passenger compartment with a test light or ohmmeter. The owner found that fuse box and reported that everything worked again.
