Thank you in advance for your help
1996 Saturn SL1 SES Light
Suggested Repair
If the dealership retrieved trouble codes pointing to the ignition coils and module, those parts need to be replaced. The quoted price is high, so get a second estimate from an independent shop. A constant service engine soon light will likely prevent an emissions test from passing until the fault is repaired.
Conversation Summary
The owner of a 1996 Saturn SL1 with 300,000 miles has a constant service engine soon light. A Saturn dealership diagnosed failed ignition coils and module and quoted nearly $900. The owner asked whether that diagnosis is certain and whether the car can pass emissions without the repair. The expert said that if the shop retrieved codes confirming that fault, those parts must be replaced, but the price is high and an independent garage may be more affordable.
