2002 Saturn Testing Electric EGR
2002 SATURN
BPISTON
Engine problem
2002 Saturn Two Wheel Drive Manual 38000 miles
2002 Saturn SL 1.9 liter. Manual transmission. Car is detonating underload when engine is warm. First switched to higher octane gas. That didn't help. Next I want to check the EGR. It is full electric operated. No vacuum supply. Removed EGR cleaned Carbon deposits. Pintle moves freely. I have no idea how to test if the EGR is actually working under acceleration. If the pintle is not moving up and down as commanded by the PCM, would it set a code? There is no code. Thanks
Dec 1, 2007 at 11:52 AM
BLACKOP555
  • 10,386 POSTS
disconnect the electircal connector and check for voltage with the ignition key on, there should be 5.0volts, next check hte resistance of th esensor the resistance should be about 5,000 ohms.
Dec 1, 2007 at 12:52 PM
