2002 Other Saturn Models Engine Cranks and Fires but won't c
2002 SATURN
WHALEYBRIAN
Engine Performance problem
2002 Other Saturn Models 4 cyl Front Wheel Drive Automatic 164K miles
Here's the problem: The engine cranks fine and has good battery. The engine fires for a few moments enough to disengage the starter and it runs for maybe a second and then stops. If the key is held in the crank position after the engine speed drops the starter usually re-engages but it will not fire again. If the key is cycled back to OFF and cranked again the engine will fire and run for another second before it stops. I've tried this many times. It has 3/4 of a tank of fuel. Any suggestions. I assume the ECM has a Crank Mode that seems to work fine but when it gets to the Run Mode something is not working right maybe a bad relay, solenoid or something?. I've disconnected the battery to try to reset any electrical components. There are no Fault Codes or Lights.
Now for the can of worms. this car was in a flood with water over the top of the steering wheel. Its my daughter's car and she only had liability insurance and doesn't have money to get a replacement. I did all the post flood checks to ensure there were no mechanical issues with water in places it shouldn't be and everthing looked good. Any suggestions or how should I approach the troubleshooting?
Jul 12, 2008 at 3:07 AM
WFB17150
2002 Other Saturn Models 4 cyl Front Wheel Drive Automatic 90K miles
I am having the same issue with my saturn. My battery recently died. I had no other problems with the vehicle, I replaced the battery and now the vehicle will not stay running. The engine will crank, fire then quit. I did not have the flood damage, but the symptoms are exactly the same.
Jul 22, 2008 at 9:28 PM
