2001 Saturn Vibration from 40mph - 70mph
2001 SATURN
68,000 MILES • 4 CYL • FWD • AUTOMATIC
SCHMIFTY00
I've been getting a vibration in my car starting at speeds of approx. 40mph and progressively getting louder until about 70mph where it levels off.
Decelerating I notice the vibrations until I get below the 40mph where it clears up abit. When I shift to neutral it persists through that as well.
I have also noticed that when I make a slight turn to the right, such as on a bend in the freeway , the vibration disappears completely. Once I straighten out it returns.
I've had my tires balanced in an attempt to correct this without any change. Any help would be greatly appreciated.
Thanks!
Dec 7, 2007 at 7:06 AM
2CARPRO JACK
  • 11,533 POSTS
Front strut ok? could be a ball joint or tie rod end letting one wheel move around at speed causing the vibration.Is it a steady noise/vibration or does it change on and off the gas? Sounds like when you turn the wheel a little it loads the suspension causing the play to go away and take the vibration with it. have a front end shop take a look at it, dont want something to break, causing a serious problem
Dec 7, 2007 at 11:50 PM
PHOENYIX
  • 13 POSTS
[quote:4e6031e139="schmifty00"]Other Category problem
2001 Saturn 4 cyl Front Wheel Drive Automatic 68000 miles
Thanks![/quote:4e6031e139]
I just went through the exact problem. I had a front wheel bearing going bad. I changed it and all is well now.
Jan 10, 2008 at 11:48 PM
