1999 Saturn SL2 Intermittent Stalling
1999 SATURN
JJBOATMAN
This car had a nerw crank sensor installed elswewhere before I got the car to work on. Had DTC's for cam sensor error (module driven, cyl #4 signal) and a I believe P1539 or so (at or near stalling condition) Car has 122,000 miles on it. never been tuned up. Installed new plugs, wires, coils/EI Module, fuel and air filters.
Codes do not return but intermittent stalling still exists per customer's daughter, never stalled for me yet.
tested crank sensor resistance, 883 ohms, not sure what brand, tested new saturn crank sensor, measured 835 ohms, cranking Hz is approx 35 Hz, Idle (not fully warmed) is approx 120 Hz at idle. Tested power grounds at PCM (.02-.06V) drop from PCM to Bat neg. all power feeds to PCM 14.2-14.3 even when wiggling key in ign switch.
Trying real hard not to get any grayer hair on this one, any help would be appreciated.
Thanks!
Mar 22, 2007 at 12:10 PM
PEPPERMRJ
  • 1,158 POSTS
Hey JJ,
Might be chasing an electrical ghost on this one. Maybe something gummed up like a EGR valve pintle or an idle air control. At close to a 100,000 miles good idea to clean them along with the throttle body.
Scope the throttle position sensor. When they are just starting to fail they will spike voltage at times but not set a code.
Wish I could get gray already am. :)
Good hunting and let us know.
Apr 4, 2007 at 1:44 AM
Suggested Repair
Clean the EGR valve pintle, idle air control valve, and throttle body. Scope the throttle position sensor for intermittent voltage spikes that may not set a code.
Conversation Summary
A 1999 Saturn SL2 with about 122,000 miles stalls intermittently after a crank sensor replacement and a tune-up that included plugs, wires, coils, the EI module, and fuel and air filters. Related codes no longer return, and power and ground checks at the PCM look normal. The expert suggests an electrical or airflow issue and recommends cleaning the EGR, idle air control, and throttle body, plus scoping the throttle position sensor for voltage spikes.
