Thank you. Great site!
Masters142
The owner confirmed the Passlock system was the cause and stopped using the key fob to lock, unlock, or arm the security system, which ended the intermittent no-crank. If it returns, check the underhood starter fuse, clean tight starter connections, and confirm 12 volts on the purple ignition wire in start; then check the ignition or safety switch, power and ground, or the combined starter and solenoid.
A 2001 Saturn SL2 with high mileage intermittently would not crank after a long drive, with normal lights and no starter sound, then started after about ten minutes. A new battery did not help. Experts suggested checking connections, the ignition switch, neutral safety or clutch switch, starter fuse, starter power and ground, and the combined starter and solenoid. The owner later reported that the Passlock system was the culprit and that avoiding key-fob lock, unlock, and security activation stopped the problem.
