1995 Saturn SL2 Sputters and Dies
RAIDERFAN17
I have a 1995 Saturn SL2 with 196759 miles. I was told a few months ago that the catalytic converter was going bad, but that I could wait until I planned to replace the car (one year) and it would be fine.
Since then my car began sputtering (almost dying). Once (after sputtering and almost dying) the engine light came on (solid) and remained on until I reached my destination.
That was about a week ago. Since then I have only driven the car short distances and it was doing fine, until last night when it died without warning. It started up right away, and I got it home.
Other sidenote, there is oil in at least one of my spark plug cylinders and I was burning oil, at least one quart every 300 miles.
I really can't afford a new car just yet.
Questions:
Could a catalytic converter cause the engine light to come on, and the car to sputter and die?
Is the engine light code stored in the car's computer even though the engine light is no longer lit?
Since the catalytic converter has been bad for a while, how much potential damage could this have caused to other areas of the car, in other words after I replaced the catalytic converter am I just going to have to replace a bunch of other parts since I was misinformed and waited so long?
What else could cause these kinds of problems?
Thank you so much.
Jan 3, 2007 at 9:10 AM
SERVICE WRITER
  • 9,123 POSTS
Need to pull codes and see what they are related to. It has the symptoms of a plugged converter. And yes it could do more damage such as burn out valves.
Jan 3, 2007 at 9:33 AM
RAIDERFAN17
Can the codes be pulled even though the engine light is no longer lit?
Jan 3, 2007 at 9:47 AM
SERVICE WRITER
  • 9,123 POSTS
Sorry missed tht questions, yes ,they will be stored in the computer as a history code.
Jan 3, 2007 at 10:00 AM
Suggested Repair
Pull stored diagnostic codes even if the check engine light is off. Symptoms match a plugged catalytic converter, which can also burn valves, so diagnose the codes before replacing parts.
Conversation Summary
The owner of a high-mileage 1995 Saturn SL2 was told the catalytic converter was failing. The car later sputtered, the check engine light came on briefly, then died and restarted. Oil is entering at least one spark plug well and oil use is high. The expert says codes remain stored as history and should be pulled; the symptoms fit a plugged converter, which can damage valves.
