Engine Performance problem
1998 Other Saturn Models 4 cyl Two Wheel Drive Manual
hello; mi car was running good but this morning don't start, like the gas don't come to the engine, it's could be the fuel filter?
Wednesday, August 27th, 2008 AT 1:11 PM
MECHANIC
Hi there,
if you have a suspected fuel system fault, you should first check for fuel pressure, this will require special tooling on most cars, but a good indication is that you should be able to hear the fuel pump run for a few seconds with the ignition on.
