1996 Saturn SL1 Hard to Shift Into First
this problem may also be cause by damage to the selected gear or the sychronizer for that gear
Suggested Repair
Because only first gear is affected, inspect the shift mechanism, linkage, and rails for misalignment or restricted travel, and check for interference between the shifter and the console or floor cutout. Also inspect the first-gear teeth and synchronizer for damage.
Conversation Summary
The owner of a 1996 Saturn SL1 with about 150,000 km reports difficulty selecting first gear, while second through fifth and reverse shift normally. First can be selected while rolling slightly, or at rest after a brief grind when the clutch is partially released. The expert says a problem limited to one gear points to a part unique to that gear, such as a damaged shift mechanism, shifter interference, restricted or misaligned linkage or rails, or damage to the gear or its synchronizer.
