HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
Other
Drivetrain
Transmission
Clutch
1996 Saturn how to blead the clutch
ROD CRABTREE
MEMBER
1996 SATURN
Transmission problem
1996 Saturn 4 cyl Front Wheel Drive Manual 120.00 miles
ther is no bleeder value
Friday, December 7th, 2007 AT 12:17 AM
MECHANIC
Loosen the tubing, when fluid stops coming out close it-do this 3x see whether it'll work. Also make sure the reservoir is full at all times.
Friday, December 7th, 2007 AT 12:34 AM
Please
login
or
register
to post a reply.
Related Transmission Clutch Content
1999 Saturn Coup
Stoped To Get Gas Got Back In Car And Put It In Gear And It Would Not Move Could It Be The Clutch I Thought A Clutch Would Give You A...
Asked by
walkergrinding
1999
SATURN OTHER
VIDEO
How to Check Your Clutch Operation?
Instructional repair video
GUIDE
Clutch Replacement
Before you replace your clutch its a good idea to see how the clutch works and the symptoms of a bad clutch. A clutch will have problems and can stop working all...
1996 Saturn Manual Transmission
I Have A 1996 Sl-1 With About 150,000 K Miles. I Am Having Difficulty Shifting Into First Gear. I Can Shift Into 2-5 And R With No Problem...
Asked by
roy.downs
1 ANSWER
1996
SATURN OTHER
Transmission Has No Reverse!!
2000 Saturn Sl2, Mileage 113,000, 4 Cyl 2.2l Dohc, Automatic Transmission. Here Is My Issue, I Had My Transmission Replaced A Year...
Asked by
ajurkiewicz
26 IMAGES
SATURN OTHER
92 Saturn S Series Will Not Shift Into Drive When Im...
92 Saturn S Series Will Not Shift Into Drive When Im Going Down The Road. It Goes Into 1st And 2nd But Wont Go Into Drive.
Asked by
teresakd3
1992
SATURN OTHER
My New 03 Saturn Ion Shifts Hard Into Drive....
Well I Just Bought A Automatic Ion With 46k Miles And I Noticed Sometimes When Shifting Into Drive From Park I Get A Clunk Noise And The Car...
Asked by
jxp8181
2003
SATURN OTHER
VIEW MORE
Clutch - How it works
Clutch and Throwout Bearing Front Wheel Drive
