1994 Other Saturn Models antifreeze leak
1994 SATURN
TONYATMR
Other Category problem
1994 Other Saturn Models 4 cyl Wheel Drive Type unknown Automatic 140000 miles
My saturn leaks antifreeze, not a lot, but enough that every week or so my "low coolant light" comes on. What causes this. My 2nd question, instead of antifreeze can I put water in the coolant chamber?
Jan 13, 2008 at 1:46 AM
TONYATMR
[quote:7da58abba3="Tonyatmr"]Other Category problem
My saturn leaks antifreeze, not a lot, but enough that every week or so my "low coolant light" comes on. What causes this. My 2nd question, instead of antifreeze can I put water in the coolant chamber?[/quote:7da58abba3]
Jan 13, 2008 at 1:47 AM
PHOENYIX
  • 13 POSTS
[quote:34cf225f9b="Tonyatmr"]Other Category problem
My saturn leaks antifreeze, not a lot, but enough that every week or so my "low coolant light" comes on. What causes this. My 2nd question, instead of antifreeze can I put water in the coolant chamber?[/quote:34cf225f9b]
First you need to find out where the coolant is leaking from and repair it. You said "leaking" so I assume there is coolant on the ground. As to adding water..... I wouldn't suggest it. In the short term it's not that big of a deal BUT over time moving parts in the cooling system will wear out because the coolant is also a lubricant, so it may cost you more down the road. If you're in a cold area the water can freeze and rupture the radiator, heater core, etc....
Jan 14, 2008 at 4:52 AM
