Replacing certainly answers it, but You would be able to see a crack. Anyways,
Do you know what codes are listed in the computer?
IF not, the next area I would go to is to clean the IAC motor and EGR valve. Not sure if you replace the IAC motor as you referenced "air control senser".
Codes, if any, would be beneficial to know.
Thursday, May 17th, 2007 AT 8:17 PM
