2003 Saturn L300 Will not start
JKBLANCO
  • 2003 SATURN L300
Engine Performance problem
2003 Saturn L300 6 cyl Front Wheel Drive Automatic
Engine cranks, will not start
Thursday, February 25th, 2010 AT 5:48 PM
Check if its fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard
Thursday, February 25th, 2010 AT 6:22 PM
