2001 Saturn L300 gas problem
JAIRO GOMEZ
  • 2001 SATURN L300
  • 4 CYL
  • 135,000 MILES
When drive car for about 15 mile estar to run out the gas bat engine not stop only no run. And then turn off and star again and continue run normal for another short mils and star the same problem.
wthat coul be de problem solution? Than you
Thursday, January 28th, 2010 AT 10:59 PM
  • 109,872 POSTS
Has the check engine light ever come on? Also, have you ever had the fuel pump pressure checked? Finally, when was the last time the fuel filter was replaced?
Thursday, January 28th, 2010 AT 11:23 PM
